For my hobby projects I've used CM since it's release due to the fact that it's free... (And i was moving away from Eag ... ehm Autodesk
Feature wise it was not bad, even if sometimes it have proper designed software locks to slow down the development)
Anyway, I have decided to try out the full Altium (for my new more complicated
project) so I have asked a trial.
I'm still having some problems in finding all the options and the keymap is partially different. My main problem so far is that i don't know a better way to quickly move stuff around.
On CM you just needed to select the components (or symbols) and with the M key you was able to move them around and by pressing SPACE it was also rotating.
Now on Altium I have to press M ath than use the mous to select an option on the context menu. Is there a better solution?
I don't have the access to the vault (beeing a demo) and it don't have lots of footprint, so I seached for a library project.
I'm using JLCPCB/LCSC a lot I I know that they have a Library for their
SMT assembly line.
I downloaded it, all the footprints are present but for the resistors.schlib file (Once the project is compiled and imported) the symbol is not present and I cannot place it.
I then tried to see if was a corrupted file, but opening directly the resistor.schlib file the symbol was present. I than created a new .schlib file and I copied the component into that.
Also this new component had an empty symbol.
What am I doing wrong?
The only solution that i've found so far is to create the symbol from scratch!
Another question that i have, on CM the layers had names like "Outline for M1". Is there a way to configure them?
If I use the "Use short name version" it shows back the M1, M2.
And so far I don't exactly know what match what.
Thanks,
hitech95
