Author Topic: Altium Designer Query  (Read 3066 times)
Offline EEVadityaTopic starter
« on: July 12, 2015, 04:59:50 pm »
Hi
I am doing project in Altium Designer 10 ,where I supposed to make seperate PCBs from single circuit , I have made the circuit on multiple schematic sheets and connected the components by "OFFPAGE" connectors.
Now I want to make pcbs where sections of circuit will be on different PCBs physically,How can I achive this Kindly give steps.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Altium Designer Query
« Reply #1 on: July 12, 2015, 08:09:10 pm »
Use three separate projects.
Seven Transistor Labs, LLC
« Reply #2 on: July 13, 2015, 04:08:36 am »
Do you have any Video Link?
Offline Psi
« Reply #3 on: July 13, 2015, 06:07:03 am »
If you're using off page connectors how are you going to specify the pcb connectors that are used to join the boards together?
« Reply #4 on: July 17, 2015, 02:50:21 pm »
I have replaced offpage connectors by net names and I will be making seperate projects.
Offline free_electron
    • SiliconValleyGarage
« Reply #5 on: July 17, 2015, 03:00:05 pm »
that doesnt work.
1 project = 1 board.   no way around it. ( actually there is )
you ned to make sure that each unique section in the schematic, that needs to be a separat board, uses unique netnames.
so instead of having one gnd you would have gnd1 gnd2 gnd gnd4 and so on.
then you can do this , but that is an ugly workaround
« Last Edit: July 17, 2015, 04:47:22 pm by free_electron »
