Author Topic: Help with broken option to mirror gerber  (Read 897 times)
Offline dmendesfTopic starter
  • Country: br
« on: September 24, 2023, 04:33:01 pm »
I´m stuck with altium 23.0.6 (stopped paying for it). I think from 22 to 23 the gerber generation panel was all changed. Nothing new was added that I could notice but a very nasty bug: The option to mirror the gerber is missing from the bar (seems it´s hidden at right but I can´t move it). Can someone with a newer Altium version generate two Outjob files, one with a layer mirrowed, so I can open it with a text editor and track how to mirror a layer by hand?  :palm:
Offline thm_w
  • Non-expert
Re: Help with broken option to mirror gerber
« Reply #1 on: September 25, 2023, 08:56:27 pm »
Your license should always let you install an earlier version of Altium as well.
I guess its in here:
OutputName2=Gerber Files
OutputCategory2=Fabrication
OutputDocumentPath2=xxx.PcbDoc
OutputVariantName2=
OutputEnabled2=1
OutputEnabled2_OutputMedium1=0
OutputEnabled2_OutputMedium2=0
OutputEnabled2_OutputMedium3=2
OutputEnabled2_OutputMedium4=0
OutputDefault2=0
Configuration2_Name1=OutputConfigurationParameter1
Configuration2_Item1=AddToAllLayerClasses.Set=...... LayerClassesMirror.Set=
Then you'll need to add the layer eg "TopLayer" or something like that.
The following users thanked this post: dmendesf
  • Country: br
« Reply #2 on: September 25, 2023, 10:54:19 pm »
Got this idea after some time. Thank you!
