Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Altium export to 3D STEP only shows component
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Altium export to 3D STEP only shows component (Read 1392 times)
kian0079
Contributor
Country:
on:
September 20, 2022, 07:23:22 am »
Hi all,
I am now having a strange problem. When I try to export my PCBdoc as a STEP and view it on Solidworks, the actual pcb board disappears and only 3D models of the components appears. Anyone knows how to fix this or what could be the issue?
Logged
thm_w
Super Contributor
Country:
Non-expert
Re: Altium export to 3D STEP only shows component
Reply #1 on:
September 20, 2022, 08:32:53 pm »
https://www.reddit.com/r/PrintedCircuitBoard/comments/xj2bia/altium_export_to_step_3d_but_actual_pcb_board_is/
Logged
Profile -> Modify profile -> Look and Layout -> Don't show users' signatures
voltsandjolts
twospoons
Frequent Contributor
Country:
Reply #2 on:
September 20, 2022, 09:09:13 pm »
Do you have any holes tangent to the edge of the PCB? Like mouse bites for breakaway tabs? That will cause the step import to fail, as Solidworks will see geometry with zero thickness - and it can't deal with that.
Logged
ANTALIFE
Country:
( ͡° ͜ʖ ͡°)
Reply #3 on:
September 26, 2022, 12:13:17 am »
Exporting as STEP has always been finicky for me, but I find "Export As Single Part" greatly helps with errors. Otherwise suggest exporting as Parasolid, especially if you are working with something like SOLIDWORKS
Logged
https://www.antalife.com/
twospoons
Country:
Reply #4 on:
September 27, 2022, 03:00:09 am »
+1 to using parasolid. I spent some time delving into the step and parasolid exports, and the step export has some poor internal object naming - which can confuse solidworks if you are importing several PCBs as step files. The parasolid files dont seem to have this issue.
Logged
Jester
Country:
Reply #5 on:
September 27, 2022, 09:51:08 pm »
My fuzzy memory tells me make sure you are viewing in 3D mode when you do the export.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
