Author Topic: Copper fill goes beyond PCB edge  (Read 3866 times)
Offline xeonTopic starter
  • Country: sk
« on: July 17, 2021, 11:39:49 am »
When making a copper fill, the copper goes beyond the edge:
It doesn't happen in any other project, and no rule seems to affect it.
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: Copper fill goes beyond PCB edge
« Reply #1 on: July 18, 2021, 11:39:43 pm »
What version of Altium, also have you tried re-pouring the copper fill? (keyboard shortcut T->G->A)
Offline pgo
« Reply #2 on: July 19, 2021, 09:50:46 am »
It may not be exactly the problem you have but I find the following the best arrangement.
- Place the board outline on the keep out layer.
This will mean that the copper pour will be set back from the edge of the board - which is a good idea in any case.
- Make sure you have 'remove isolated copper' (from memory) on the copper pour.
bye
Offline Phoenix
« Reply #3 on: July 21, 2021, 10:29:58 pm »
Add a design rule for it
1. Design -> Rules
2. Manufacturing -> BoardOutlineClearance
3. Right click -> New rule
4. Select the new rule and add a minimum spacing say 0.5mm, 1mm or whatever your requirement is.
5. Repour polygons (t -> g -> a)
This will also stop you drawing tracks too close to the edge as well.
The following users thanked this post: SteveyG
Offline SteveyG
  • Soldering Equipment Guru
« Reply #4 on: July 22, 2021, 05:25:38 pm »
As above, easiest way is to create a design rule. The other way is to create the polygon pour from the board outline.
Is your board outline complete? I can't see why it would create a polygon pour in such a way in the first place.
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
