Author Topic: Filter: Free Pads  (Read 1421 times)
Online T3sl4co1lTopic starter
    • Seven Transistor Labs
Filter: Free Pads
« on: March 03, 2017, 05:04:20 pm »
I was just adding fiducials to an existing design, and took the lazy route, adding free pads.  Nothing wrong with that, really.
Place, Pad
Name: FID1 (autoincrements as I place more)
Size: 40 mils (round pad)
Solder mask expansion: 20 mils
Layer: Top Copper (and Bottom, whichever need it)
Net: No Net
There's a polygon pour, so I need to set clearance.
New clearance rule:
Query: IsPad AND (Name Like 'FID*')
Constraint: 20 mil
No effect.  ???
I test queries.  Like '*FID*' works.  Huh.  '?FID*' doesn't work.  Two ?? doesn't work, and so on.  Five ?'s works.  Huh...
On a hunch, try 'Free-FID*'.  Works.  Huh.
The object clearly says its Name, in the three places you can view it (dialog, Inspector and List).  It's a Free pad, so of course, the Component property is prepended to the internal name: in this case, 'Free-'.
Just something to keep in mind.  Happy querying,
Seven Transistor Labs, LLC
Offline HWgeek
Re: Filter: Free Pads
« Reply #1 on: March 09, 2017, 01:10:59 pm »
Good one, thanks!
Sent from my iPhone using Tapatalk
