Author Topic: Place Via (PV) and preset via sizes  (Read 1534 times)
Offline poorchavaTopic starter
  • Troll Cave Electronics!
« on: May 20, 2016, 12:18:03 pm »
Is there a way to somehow select via properties from a list of predefined favourite via styles when using 'p-v' command? I mean in a similar fashion to how it is done during Interactive Routing?
Online T3sl4co1l
    • Seven Transistor Labs
Re: Place Via (PV) and preset via sizes
« Reply #1 on: May 20, 2016, 10:08:43 pm »
I don't think so.
There's P, T, (click), 2, (click), (right click), (right click) (don't move mouse between first two clicks), but that's slow.
FWIW, P,V sets default other via properties, like tenting and test points.  Can be useful, or annoying if you forget.
Seven Transistor Labs, LLC
Offline ajb
« Reply #2 on: May 23, 2016, 03:13:10 am »
Maybe I'm missing something, but what's wrong with P,V, <Tab> and select a via style from the template drop down?  (I think hole/via templates appeared in 16, or maybe 15.8ish?)
