Author Topic: Display Component Comments on PCB  (Read 1425 times)
Offline theatrical sceneTopic starter
« on: January 23, 2019, 03:00:44 am »
When laying out a PCB in AD18, only the component designators show up on the top overlay/silkscreen layer. How would I go about including the comment/value parameters such that a resistor shows "10K" rather than "R1" (and so on)?
Offline Batang
  • Country: my
Re: Display Component Comments on PCB
« Reply #1 on: January 23, 2019, 03:41:07 am »
For AD17, I would assume that AD18 is the same.
As per the image.
Cheers
« Last Edit: January 23, 2019, 03:47:32 am by Batang »
The following users thanked this post: theatrical scene
« Reply #2 on: January 23, 2019, 03:50:12 am »
Awesome thanks! Did you get to that menu by right clicking on the part and selecting "component actions"?
Offline Batang
  • Country: my
« Reply #3 on: January 23, 2019, 03:56:16 am »
Double clicking on the part in the PCB editor if the part is locked
or left click on unlocked part to select it and then right click for context menu and select Properties.
Cheers
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: January 23, 2019, 03:56:16 am »
Component properties.  Double-click; or right-click, Properties; or use the Properties window (formerly Inspector Panel).
I don't think you can get SCH parameters on the PCB but you can copy them to the Comment field where it will sync.  Use Parameter Manager or SCH List to do this.
Seven Transistor Labs, LLC
