Author Topic: Renamed Database Library  (Read 1423 times)
Offline DavidTopic starter
« on: October 08, 2020, 10:18:32 am »
Hi all,
I have a large database library which I have moved and renamed. Is there anyway to easily get schematics to point to the new database library without changing each component individually? I'm sure I remember an option to do this? I thought it was in update from libraries but nothing obvious there?
Cheers,
Dave
(United Kingdom)
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Renamed Database Library
« Reply #1 on: October 08, 2020, 05:09:40 pm »
I think it is Tools > Item Manager, but i have never had to do this.
“They Don’t Think It Be Like It Is, But It Do”
« Reply #2 on: October 08, 2020, 05:44:02 pm »
I tried that but didn't find anything useful. I can't believe this is so hard. Surely this must be a common occurrence!
(United Kingdom)
Offline Pseudobyte
« Reply #3 on: October 08, 2020, 08:18:26 pm »
I think you should be able to change that property using the parameter manager. Filter on only parts and then change the Library column for all parts. I think that should work. Recompile after doing that and see if anything breaks.
« Reply #4 on: October 09, 2020, 06:59:00 am »
You sir are a legend! Thank you so much. I had the "Exclude system parameters" box checked so I couldn't see the library column!  :palm: Thanks again!
(United Kingdom)
