Better, I'd dare say. Probably OrCAD has this too, I don't recall?
Anyway, best way is to apply a net class to the nets in question. This is done on the schematic. On the PCB, create a rule for objects in that class. Can even specify some rules from the SCH.
Next option is to call out the nets individually (with a query like "InNet('MyNet1') OR InNet('MyNet2') OR ..."), but this sucks as net names can change more often, or accidentally. Especially if referencing auto-named nets.
There are also associations with components, pads, or rooms, which may be helpful.
