Author Topic: Rules are driving me nuts... Some help would be appreciated  (Read 3097 times)
Offline Ice-TeaTopic starter
    • Freelance Hardware Engineer
« on: February 16, 2016, 07:47:06 pm »
This is driving me bonkers. I have a PCB with some stringent isolation requirements. So, obviously, I need some rules. They seem to work, kinda, but also not. For simplicity, I disabled most rules except for these:
Basically, "regular" 0.2mm clearance, 6.1mm clearance on outer layers and 2.5mm on inner layers. So far so good. Now look at the picture. I took a trace from "IO3" and routed it towards "IO2". Obviously, the rules made me "hit the wall". You can see a 6.1mm clearance to a pad (SOIC IC) with "ISO2", which is correct. It also shows the clearance to a much closer pad, basically the TH pad of a Y2 cap. Clearance there is much less, less than 2.5mm even.
So... What the heck is going on?? From what I can tell, all TH constructs (including vias I think) are not taken into account for the clearance... So, why? And how can I fix it?
Offline AlfBaz
Re: Rules are driving me nuts... Some help would be appreciated
« Reply #1 on: February 16, 2016, 08:07:14 pm »
Bit of a gotcha I guess. Whilst through hole pads and vias have parts of them ton the top layer they are actually classed as being on the "Multilayer"
« Reply #2 on: February 16, 2016, 09:08:55 pm »
So, as far as rules go they do not exist on top and bottom per example?  :wtf:
Kill me now...  |O
« Reply #3 on: February 16, 2016, 09:56:02 pm »
OK... follow up question.I can see how I could cook up a rule against "Multilayer". But how then would I make a rule that would have a different clearance for multilayer parts on outer and inner layers??  :scared:
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: February 16, 2016, 09:59:59 pm »
Try (OnOutside OR OnMultiLayer) instead of named layers. :)
Seven Transistor Labs, LLC
« Reply #5 on: February 21, 2016, 09:06:50 pm »
Yep, that's better. Now for the following part: a mechanical, non-plated hole is also a multilayer part. So that also generates errors where it should not. Can obviously exclude "No Net" parts but my clearance rules are starting to read like an encyclopedia.
Offline T3sl4co1l
« Reply #6 on: February 22, 2016, 07:01:33 pm »
They don't have to be pretty, they just have to work...
And hey, it's not like it's the tax code (which doesn't even have to work!)...
« Reply #7 on: February 22, 2016, 08:53:35 pm »
Ah, well, this is where the customer disagrees. He likes things pretty.
Offline free_electron
    • SiliconValleyGarage
« Reply #8 on: February 22, 2016, 09:36:07 pm »
ONOUTSIDE OR ISVIA OR ISPAD
