Hey guys!
A few days ago I tried to create my first DB library based on an Excel table. The library contained a few thousands of chip resistors in different packages. When I add one of the resistors on a schematic I saw that it had two footprints: the right one, like in the Excel table, and... the second one. I have no idea where the second came from, it wasn't in the table!
After some research I found that the resistors in the 0402 package were fine (they were the first in the table). All others had two footprints - the right one and 0402. Also the right footprints had the empty description field (you can see it on the screenshots above). I tried to create the library with only two components and got the same result.
I attached the archive with this library if you want to see it yourself. Just in case, I have Altium Designer 19.1.5 and MS Office 2010. Do you have any ideas on how to fix this issue? Maybe I'm doing something wrong?
