Author Topic: Coordinates following the cursor  (Read 2352 times)
Offline AmmarTopic starter
« on: October 31, 2019, 04:55:10 am »
Any Altium wizards want to tell me how to stop the coordinates following my cursor? Not sure what I pressed but they usually behave and sit in the corner.
Sorry for the terrible quality gif.
Offline SerieZ
  • Zap!
Re: Coordinates following the cursor
« Reply #1 on: October 31, 2019, 07:32:20 am »
Shift+h and you will never have to see that Monstrosity of a Box again. I personally never used it and it has annoyed me far too often.
I have never seen the Issue you have tho, if you really want to keep the box look into Heads Up Display, that is how that thing is called.
 :palm: :palm: :palm:
As easy as paint by number.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: October 31, 2019, 07:53:15 am »
View - Board Insight
has all the controls you need.
Seems you hit SHIFT+G at some point!
Personally, I prefer the heads-up, with SHIFT+D (delta) enabled.  Never found the tracking or magnifier settings useful or even pleasant.
SHIFT+S (toggle single layer view) is another handy one that you may discover frustratingly by accident. :)
Seven Transistor Labs, LLC
The following users thanked this post: SerieZ
Offline mengfei
  • Country: ph
« Reply #3 on: October 31, 2019, 08:13:19 am »
Never had any use for that.
Always OFF  :phew:
Offline SerieZ
  • Zap!
« Reply #4 on: October 31, 2019, 09:55:01 am »
Shift + S is an extremely useful shortcut in my Opinion.
I use it all the time.
I dont get why you would ever want to use Shift + G tho.  :-DD
Offline Psi
« Reply #5 on: October 31, 2019, 10:02:17 am »
Ah, the good old coordinates following cursor problem.
Sooner or later everyone turns that on by accident.
« Reply #6 on: October 31, 2019, 10:26:15 pm »
Yeah, I use Shift + S all the time. Thanks Altium brains trust, all fixed. I find the heads up display useful when it's not following my cursor. Why would anyone want it to follow their cursor?
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
« Reply #7 on: November 01, 2019, 12:56:04 pm »
It is useful when you run at high resolutions like 4k.
“They Don’t Think It Be Like It Is, But It Do”
Offline toybuilder
« Reply #8 on: November 05, 2019, 10:28:05 am »
When you're plunking down a bunch of passives in a cluster and don't want to remember which component has which value, the hover-over information is quite useful.  I use it to figure out which of the several bypass caps has the lower capacitance, to be placed closer to the IC.  Otherwise, I have to cross-select.  It's faster to use the heads-up.
