Hi all,
I am running into issues setting non-plated through hole in Altium. I have configured hole as mounting hole 3.08 mm non-plated, 0.127 mm solder mask expansion. When I unselect pad option as plated and run through DRC and DFM check, here is what I see:
1. DRC Error: Unplated multi-layer pad(s) detected
2. DFM error from 4PCB: Insufficient Inner Spacing.
I am trying to understand where and how to fix this issue? Can someone please advise?
tarun172
