I'm using Protel/EDA client and occasionally have a problem with updating PCB versions.
What I normally do when I want to modify an existing PCB design and up-issue it is as follows:
I select the entire board by drawing a block around it.
I press control C and click on the lower left corner of the board.
I then open a new PCB document in the same folder, with a different name.
I then press control V to paste the selected board.
I repeat the process with the schematic and link the new schematic with the new PCB.
The problem that I have is that sometimes the existing PC board traces are not recognised by the netlist and a rats nest appears on the PC board. Upon inspection of the traces they all have "no net" as the assigned net.
To solve the problem I have to go and manually alter the net name of EVERY friggen trace to remove the rats nest line.
What am I doing wrong and how can I get the program to recognise the existing traces on the board?
Dick
