Author Topic: Delete key not working  (Read 4479 times)
Offline MordorGuyTopic starter
  • Country: hr
« on: March 04, 2020, 11:26:05 am »
Altium 20.0.11/12
I have a problem in which delete key stopped working, I can cut traces, click edit-delete but physical key does nothing
Shift+DEL works but its annoying to click that much
In schematic everything is working
Is there a solution for this?
« Last Edit: March 04, 2020, 11:30:50 am by MordorGuy »
Offline Psi
Re: Delete key not working
« Reply #1 on: March 04, 2020, 11:29:42 am »
Reboot your machine, sometimes a key or keys just stops working in windows apps.
A reboot always fixes it for me.
  • Country: hr
« Reply #2 on: March 04, 2020, 11:38:49 am »
Unfortunately neither version update nor PC restart didnt help.
Offline Psi
« Reply #3 on: March 04, 2020, 11:53:48 am »
hm.. Does the delete key work in other apps?
Can you use the delete key in Altium to delete characters from text strings?
  • Country: hr
« Reply #4 on: March 04, 2020, 12:00:38 pm »
Yes, it works, and combination shift+DEL works for deleting
Also numpad + and - doesnt work to scroll through layers
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: March 04, 2020, 01:33:32 pm »
Did you disable a shortcut menu, by any chance?  (Right click toolbar area, see list of available toolbars?)
Seven Transistor Labs, LLC
The following users thanked this post: ANTALIFE
  • Country: hr
« Reply #6 on: March 04, 2020, 01:48:13 pm »
Yes, the toolbar "PCB shortcuts" was disabled and nothing worked, thanks for your help
« Last Edit: March 04, 2020, 01:54:35 pm by MordorGuy »
