Author Topic: Altium Designer 18 creating design rules for polygon classes (SOLVED)  (Read 2299 times)
Offline mzbasTopic starter
  • Country: tr
I wanted to know if there is a way to create design rules for polygon classes. I'm trying to create a clearance rule for multiple polygons, and do not want to add them one by one in the design rules window. So I decided to create a polygon class so I could assign the rule to that. But I could not find a condition type like "InPolygonClass". All answer are appreciated, thank you.
« Last Edit: March 18, 2019, 07:14:58 am by mzbas »
  • Country: tr
Re: Altium Designer 18 creating design rules for polygon classes
« Reply #1 on: February 27, 2019, 10:41:19 am »
Instead of assigning rule to the polygon class i have created a net class and added the polygon nets to it. I created the clearance rule for the nets class. This worked but still wondering if the is a way to do this in a way mentioned in my first question. I have seen it for circuit studio but not in Altium 18. The link for circuit studio is below.
http://documentation.circuitstudio.com/display/CSTU/((Added+Support+for+Polygon+Classes))_CS
Offline Psi
« Reply #2 on: February 27, 2019, 11:24:23 am »
i dont have time to check right now, but keep in mind Altium has a few weird naming systems.
stuff like
InPolygon  vs IsPolygon,  that sort of thing.
Try searching for stuff like that, one of them should work for all polygons.
« Last Edit: February 27, 2019, 11:26:01 am by Psi »
The following users thanked this post: mzbas
Offline ajb
« Reply #3 on: February 27, 2019, 03:23:43 pm »
Works for me  :-//
  • Country: tr
« Reply #4 on: February 28, 2019, 05:29:15 am »
Works for me  :-//
I have tried it again, by writing InPolygonClass in the window. Perhaps I had done a syntax error in the previous tries, or was confused because I couldn't find it in the query builder/helper. It works now, thanks you for your help :)
