However you draw it, be sure to discuss the castellations with your PCB fabricator. If they run this through their typical process you likely won't achieve good results. Routing straight through a fully plated hole usually results in the copper outside the route line getting crammed into the hole, so generally they'll either adjust the routing CAM or route across the holes before final plating.
