Author Topic: Altium 2D - nets not showing !  (Read 4190 times)
Offline maxpayneTopic starter
« on: May 06, 2016, 12:03:00 pm »
I am facing a strange problem in Altium 16.1.7
In the PCB window, the nets are not appearing. I have pressed N>show connection>All, but still the nets are not appearing. Also the pad holes are not shown. But in 3d view I can see everything.
Am I missing something ?
Online T3sl4co1l
    • Seven Transistor Labs
Re: Altium 2D - nets not showing !
« Reply #1 on: May 06, 2016, 02:53:55 pm »
Try bottom left, layer manager, turn on all?
The background color is awfully close to the net color too, though that shouldn't matter within the PCB area.
Seven Transistor Labs, LLC
The following users thanked this post: maxpayne
« Reply #2 on: May 06, 2016, 02:56:09 pm »
I solved it a while ago by changing the 2d color profiles and select default>classic>default and it worked. also the pad holes appeared !
