Author Topic: Polygon won't connect to ground  (Read 2613 times)
Offline PlectoTopic starter
« on: September 26, 2018, 10:55:02 am »
I suddenly came over a weird problem that I've never encountered before, my polygons won't connect to same net pads. They do connect if I choose 'hatched' instead of 'solid', they will also connect if I change the polygon connect rule to 'direct connect' instead of 'relief connect', but I don't want my polygons hatched and I don't want direct connection. Can anyone help me?
Online Psi
Re: Polygon won't connect to ground
« Reply #1 on: September 26, 2018, 11:22:36 am »
can you post your altium file, or make a new file with the same issue.
Then we can try to figure out what rule is causing your problem.
« Reply #2 on: September 26, 2018, 11:52:46 am »
This is a work related project so I can't post it here. The problem is not with any other projects so I'm afraid I can't replicate it either.
Online Psi
« Reply #3 on: September 26, 2018, 12:19:36 pm »
drag a box around the entire PCB, copy/paste it into a copy of another project without the issue.
i'm pretty sure this is a design rule issue though, there will be some odd rule configured somewhere.
You could just start deleting all your custom rules until it starts working.
« Last Edit: September 26, 2018, 12:23:38 pm by Psi »
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: October 11, 2018, 04:03:55 pm »
make sure that 'pour over all same net object' is checked
