Author Topic: Measuring distances for pcb library  (Read 2862 times)
Offline mov-jumpTopic starter
  • Country: ir
« on: March 11, 2016, 07:02:24 pm »
Hello
I am creating a pcb library, so now I wanna draw line on top overlay and I want to draw it in exact size from datasheet.
I know it can be possible by measuring distance tools but it can be a bit difficult to draw in this way.
Is there another way to draw a square shape in exact size ??
Thx in advanced
Offline uncle_bob
Re: Measuring distances for pcb library
« Reply #1 on: March 12, 2016, 02:15:29 am »
Hello
Thx in advanced
Hi
With some packages, you draw an arbitrary square and then click on properties. You enter the correct dimensions in that pop up and that's all there is to it.
Bob
Offline exmadscientist
  • Technically A Professional
« Reply #2 on: March 12, 2016, 03:24:49 am »
Or just use the "PCB Inspector" panel. Draw something approximately correct, arrange it to be perfect using the Inspector, and copy-and-paste as required.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: March 12, 2016, 04:00:02 pm »
Or set the grid to the appropriate unit and any fraction of the desired measurement.
If you want to show the dimension for some reason, that's under P, D, L (Place/Dimension/Linear), or the other kinds.
Seven Transistor Labs, LLC
Offline voltsandjolts
« Reply #4 on: March 12, 2016, 04:49:46 pm »
For simple shapes I tend to use the jump dialog. Start off with JR to work from origin then series of JL to draw shape outline then move whole shape to where I want it.
Offline kendalll
« Reply #5 on: March 12, 2016, 07:27:25 pm »
I temporarily set the origin to the corner of the shape I'm drawing then edit the line lengths in their properties to get exact dimensions.
  • Country: ir
« Reply #6 on: March 13, 2016, 09:26:02 pm »
thank you with these ways.   :-+
I drew it perfectly with your help specially linear dimension.
Now I have another problem with Auto routing which that must be in the other topic (for category forum rule)
Offline uncle_bob
« Reply #7 on: March 14, 2016, 01:56:44 am »
Hi
The simple answer for auto routing issues ... don't use auto routing.:)
Bob
Offline ajb
« Reply #8 on: March 14, 2016, 05:34:59 pm »
For more complex shapes you can also import a dxf or dwg.  It's a bit clunky, though, and not often worth the trouble of firing up a proper drawing program, but if you want to do something really detailed and accurate for some reason it could be worthwhile.
