Author Topic: Interactive routing collision problem  (Read 2620 times)
Offline MotonautTopic starter
« on: February 15, 2022, 09:56:18 pm »
I have this really weird problem where I seem to have disabled interactive routing collision avoidance. When I route my traces my routing neither pushes or hugs other objects and it does not give any live DRC errors for overlapping nets. I have checked my preferences and tried several modes for conflict resolution. I cant figure out what I have enabled/disabled to create this problem.  |O
Please help out. Thanks
Offline thm_w
  • Non-expert
Re: Interactive routing collision problem
« Reply #2 on: February 16, 2022, 01:17:54 am »
It wasnt for clearance and short circuits. So now it detects live clearance and short circuits but the interactive routing still wont hug or push.
EDIT: Just got a weird interactions where the interactive routing pushed vias in the same net.
« Last Edit: February 16, 2022, 01:33:32 am by Motonaut »
Offline exmadscientist
  • Technically A Professional
« Reply #3 on: February 16, 2022, 08:06:41 am »
It sounds like perhaps you have the Interactive Routing Conflict Resolution option set to "Ignore Obstacles"? This can be very useful for some work, but is usually not what one wants.
« Reply #4 on: February 16, 2022, 03:04:36 pm »
Here is my Interactive Routing settings: http://prntscr.com/26x0e5l
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
« Reply #5 on: February 24, 2022, 02:26:46 pm »
I stopped using the regular routing command and switched to quick route, more responsive, more predictable.
“They Don’t Think It Be Like It Is, But It Do”
Offline tooki
« Reply #6 on: April 11, 2022, 06:36:06 pm »
Are you aware that those settings are only for selecting which modes are available to be selected? You still have to select the mode you want. Press Shift-R while routing to cycle between modes.
