this antenna needs to be specially designed according with the pcb material. antennas are affected by the pcb dielectric, surrounding objects and cavities and outer box even it is plastic.
This type of ready-made antennas are used in low power transmitters such as wifi, bluetooth and ism. but this is not a good idea in a transmitter that generates around 2w power such as 4.5g-gsm
At the same time, 4.5 is not on a single frequency like wifi/BT/ISM. it contains many different bands, so it may not be easy to design, test and realise such an antenna.
