Author Topic: 3DPDF panelized PCB bug?  (Read 3319 times)
Offline ANTALIFETopic starter
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« on: June 27, 2016, 11:45:35 pm »
Hello m8's
Just wondering if anyone has experienced this bug in Altium, exporting a 3DPDF file of a panelized PCB (using Embedded Board Array function) gives a blank board. But doing the same for a single board works just fine  :-//
Is there a solution for this?
Cheers
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: 3DPDF panelized PCB bug?
« Reply #1 on: July 08, 2016, 01:36:56 am »
Turns out this is a known problem which will hopefully be fixed in future updated. Here is the email I got:
The Embedded Board Array is not currently supported by the 3D PDF feature. There is a feature request ticket with the Development Team requesting that this issue be investigated and resolved at the earliest opportunity.
One possible workaround would be to use a pseudo panel for the 3D PDF output, create a copy of the panel geometry, then export the original PCB as a STEP, then place a 3D Body in the pseudo panel and embed the exported STEP.
Offline technotronix
    • PCB Assembly
« Reply #2 on: August 22, 2016, 12:30:59 pm »
I also had the same problem before few months. And still looking for solution.
