Hello everyone,
i've been strugling with a specific compiler error for days with my altium 10.1377.27009 and couldn't figure what cause it to pop:
On my design there are several Device Sheet connected together on a top sheet (hierarchical topology), some of them feature several differential pairs of net properly named XXX_P and XXX_N via netLabbel and each having a "DifferentialPair" parameter set.
Because of the topology some of these net have multiple netName, however i took care of using the YYY_P and YYY_N naming scheme on every device sheet and top sheet.
Now about the compiler error, i have several of these:
Missing Negative Net for differential pair [N00368], positive net [N00368]
where [N00368] change from one net to another.
What bother me here is:
- i couldn't find anyhting wrong in my knowing in the process to declare these net as differential pairs
- when using the "Compile Error" box to pinpoint these error location, it lead to nowhere (one device sheet having differential pair is displayed but everything on it is fadded white, no highlight). see attached screenshot
- the netName [N00xxx] doesn't look conventionnal to me and i couldn't find any of my net having a name like that in the various altium tools and menus i know.
- as far as i can tell, in the pcb editor, differentialPairs all seems to be properly registered by altium
Does anyone had this compile error out there and have a clue about how to fix it? thank you very much.
A.
