Author Topic: Problem with editor window pads in Altium Designer 2013  (Read 3992 times)
Offline JaisonTopic starter
  • Country: br
« on: July 26, 2013, 01:55:52 pm »
Hello! when I open the window to edit a pad the OK button is hidden, overlapped by the toolbar, even hiding the toolbar windows can not use the ok button, anyone ever had this problem?
« Last Edit: July 26, 2013, 01:57:48 pm by Jaison »
Offline Psi
Re: Problem with editor window pads in Altium Designer 2013
« Reply #1 on: July 26, 2013, 02:13:37 pm »
PCB design is always done on large monitors (24" 1920x1200 etc) and often 3 of them in a row!
Trying to do it with only 768 vertical pixels is a little crazy :P
In any case, to fix your current problem just set the taskbar to auto-hide mode.
That will give you some extra room and allow you to click the buttons.
( right click on the taskbar / properties / tick 'auto hide the taskbar' )
« Last Edit: July 26, 2013, 02:15:39 pm by Psi »
Offline Rufus
« Reply #2 on: July 26, 2013, 02:45:35 pm »
Altium designers minimum screen requirement is 1280x1024 with strong recommendation for larger and secondary screens.
  • Country: br
« Reply #3 on: July 26, 2013, 03:16:26 pm »
I concealed the toolbar now stayed best to work, thanks for the help!
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: July 26, 2013, 03:52:32 pm »
i guess you figured it out. but all joking aside : you really need to get a higher resolution screen.
Altium gets very frustrating if you run it on a cramped display.
get a nice widescreen 1920x1080 or , if you can afford it : two of those. or 1920x1200 (LA2405x)
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: July 26, 2013, 04:51:25 pm »
i suspect he's running it from a laptop or netbook. App for ipad galaxy isnt ready?
