I'm doing a multi-channel design.
Basically I have 12 rooms that will repeat the exact same subcircuit on the PCB.
Now, I find rooms quite good at what I want them to do (being able to repeat a circuit).
But I wonder... if I use polygon pours inside a room (even inside the top layer), when I try to move the room, the room components/traces move except the newly created polygon pour!
Is there a way to associate a polygon pour to a room?
Because since this is a 4 layer board, I would like to be able to add ground pours (on layer two) and power pours (layer 3) to the room, so that I could just repeat this all over 12 times.
Is this possible or do rooms only apply to basic stuff like traces and components?
Thanks!
