Author Topic: fabrication layer output altium  (Read 3447 times)
Offline MorgorothTopic starter
  • Country: cl
« on: August 07, 2016, 06:17:43 am »
 I've searched a lot in Altium configuration trying to get a fancy fabrication layer output like in the attached images, but without success, so if someone know the secret configuration please share it.
Google hasn't been a help on this and I really want a nice output fabrication layer for my PCB.  :box: :box:
 :scared: :scared: :scared:
Thanks in advance,
 JP
If works, doesn't means it is right.
Online T3sl4co1l
    • Seven Transistor Labs
Re: fabrication layer output altium
« Reply #1 on: August 07, 2016, 08:23:27 pm »
Design / Board Options, Display Sheet
This gives you the white background.  I never use it, personally, because PCB view isn't made to work with a white background, and it doesn't do anything otherwise.
Place / Drill Table
Place / Layer Stack Table
If you are using through holes, the default Drill Table settings will be fine.  If using blind holes, it's probably a good idea to place several tables, and change their settings to each layer pair, or include the column that says which layer pairs a hole belongs to.
To add the mechanical-sheet stuff (the row/column margins, rev block, title block), you need primitives, probably copied from another template project.  I don't use these either personally, but I have customers who do.
Seven Transistor Labs, LLC
The following users thanked this post: aandrew
  • Country: cl
« Reply #2 on: August 07, 2016, 10:21:04 pm »
Works great !!!, ty !!
Offline dodonny
« Reply #3 on: May 16, 2020, 05:01:09 pm »
I'm posting here new information for people like me who looking for this parameter in the new version of Altium Designer.
Because Design>Board Options>Display Sheet does not exist anymore.
Click in gray background (select nothing)  > Proprieties panel > on the bottom of the bar > Sheet Settings
I looked for this for about 1 hour... this is why I reply to this old post.
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
« Reply #4 on: May 18, 2020, 01:21:38 pm »
Or you can just press shift+c to clear any selection.  :-+
“They Don’t Think It Be Like It Is, But It Do”
