Author Topic: How can I mirror the top overlay to the bottom overlay  (Read 9625 times)
Offline sensoTopic starter
  • Country: pt
    • My AVR tutorials
« on: August 10, 2013, 01:07:30 am »
Good night, I have been designing a simple degree wheel to measure timing of ignition and transfers in two stroke engines, getting 10 pcb's from china is cheaper and sturdier than some laser engraved acrilic, so I thought about using the pcb's as a cheap and durable substitute, I have already designed the top overlay, but I don't know how to mirror/flip a copy of the top, to the bottom, here is a image:
I already have a copy of the overlay, but when I select all the items and double click, only the text goes to the bottom overlay, and no mirroring is happening, I know it must be as easy as two or three button presses, but I can't find how  :-[
Offline Rufus
Re: How can I mirror the top overlay to the bottom overlay
« Reply #1 on: August 10, 2013, 01:18:41 am »
Select and copy. Make bottom overlay current. Edit | Paste Special and select onto current layer. Hit X to flip in the X axis before clicking to complete the paste.
  • Country: pt
    • My AVR tutorials
« Reply #2 on: August 10, 2013, 01:27:48 am »
Many thanks, I sure was doing it the wrong way  :D
Offline Psi
« Reply #3 on: August 10, 2013, 03:20:36 am »
It looks like you're using the silkscreen overlay for your text and lines.
Just a thought, maybe ENIG tracks would be better ?
Silkscreen quality can vary quite a bit. Sometimes it's a kind of dotmatrix and looks crap for anything but vertical/horizontal lines, where as the copper is photo etched so you get nice and sharp lines.
I wouldn't get silver due to it tarnishing but ENIG(gold) would look good.
Just remember, if you do want exposed metal you need both a copper layer and a soldermask layer to expose it.
« Last Edit: August 10, 2013, 03:23:13 am by Psi »
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: August 10, 2013, 01:43:48 pm »
Select all S A
In the inspector , change layer to top layer.
Now, everything is copper.
While everything is still selected , press L
This will swap everything to the bottom layer and mirror it.
While stuff is still selected in the inspector change it to bottom silkscreen.
Alternate route :
S A E C X
Change to bottom silkscreen in inspector
E P
