Hello, I don't change altium shematic and pcb default values permanently. (.dft files)
For example I change wire color, pin length etc and I checked permenent checkbox(or uncheck) and apply/OK but If i restart Altium, all settings are gone.
I also save my settings, it doesn't work. (I started altium as admin). I didn't find the problem
I use 20.1.11. (x64). I think the problem is caused by encoding(because I see "?" characters in dft file), I can change altium encoding?
Or how can I find the problem? please can you help me?
