Author Topic: Using EasyEDA library in Altium  (Read 1660 times)
Online lutkeveldTopic starter
« on: December 26, 2023, 09:49:11 pm »
Does anyone know if there are ways, or ongoing efforts, to easily import EasyEDA library items into Altium?
Now using the JLC PCBA service more often, I often use chinese parts which already have an EasyEDA library item.
Manually copying it is quite tedious and error-prone.
I have seen options to export complete designs, but that would be quite tedious still for single library items, if it even works at all.
Offline thm_w
  • Non-expert
Re: Using EasyEDA library in Altium
« Reply #1 on: December 27, 2023, 09:59:12 pm »
Can try export it from easyeda: https://docs.easyeda.com/en/Export/Export-Altium/index.html
"EasyEDA does not support exporting the Symbol or Footprint in Altium Designer library format, but you can place the libraries with the schematic or PCB and export that in Altium Designer format, and then extract the libraries from Altium Designer."
Might also be able to do it through kicad: https://github.com/uPesy/easyeda2kicad.py
