Author Topic: Unused pad clearance  (Read 1896 times)
Offline hamdi.tnTopic starter
  • Country: tn
« on: May 28, 2015, 10:01:35 am »
The situation is i have a board with high voltage side and low voltage side, and have to keep 8mm between both side, i put all nets on the HV side in a class (with netclass directive) and they have their proper clearance rule as well 0.8mm .
i have a connector with main voltage in it, but have an unused pin, the online DRC show that track on the other pins need to be far 8mm from it  :-// this is quite normal since their is no net in it , so basically it's not within that HV class.
am trying to configure the rule so that unused pad don't generate a clearance error and follow the same clearance applied to the HV nets.
Thanks  :D
  • Country: tn
Re: Unused pad clearance
« Reply #1 on: May 28, 2015, 10:29:30 am »
Done ...  was too damn obvious :palm:
