Author Topic: tracks terminated in squares, not semi-circles  (Read 9514 times)
Offline Dreamer1Topic starter
« on: September 06, 2015, 09:46:27 pm »
Is it possible to do what the title says in altium 14+?
Offline armandas
  • Country: jp
    • My projects
Re: tracks terminated in squares, not semi-circles
« Reply #1 on: September 06, 2015, 10:04:34 pm »
No, tracks are always rounded.
« Reply #2 on: September 06, 2015, 10:06:48 pm »
How can I accomplish what I need?
Offline dave_k
« Reply #3 on: September 06, 2015, 10:18:11 pm »
Put a square pad at the end with zero hole size ...
Offline armandas
  • Country: jp
    • My projects
« Reply #4 on: September 06, 2015, 10:23:57 pm »
Maybe you should start by telling us what is it that you need?
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: September 06, 2015, 10:40:05 pm »
Kind of Devil's Advocate here:
Produce outputs.
Find the aperture definitions in the gerbers.
Edit them to produce square tracks (or octagonal, or..).
YMMV if this looks bad on some places.  It will absolutely reduce clearance around diagonal traces.
Seven Transistor Labs, LLC
Offline sean0118
« Reply #6 on: December 17, 2015, 05:54:03 am »
Yeah, I ran into the same problem. It's surprising that Altium doesn't have an option for square ended tracks.
If you're using an 0402 SMD package the two rounded ends of the tracks can nearly touch in the centre. It seems the only way around it using the GUI is to place a fill instead of a track?   ???
« Last Edit: December 17, 2015, 06:09:05 am by sean0118 »
Offline sean0118
« Reply #7 on: December 17, 2015, 06:11:36 am »
Then why the centers of pad of your 0402 package are too close?
Because just going to the edge of the pad is dodgy, square ends would be much nicer.  :D
