Author Topic: Polygon poor solder mask  (Read 5231 times)
Offline safarirTopic starter
« on: July 19, 2013, 05:59:24 pm »
I am working on a board and I want to tin some very complex polygon poor. What the best way ? They are very complex and I don't want to redraw them ...
Sorry for my bad english,
Thanks for your answers :)
Offline free_electron
    • SiliconValleyGarage
Re: Polygon poor solder mask
« Reply #1 on: July 19, 2013, 06:56:31 pm »
emg : edit-move -polygon vertex
then click on the polygon and start moving.
Offline marshallh
    • retroactive
« Reply #2 on: July 20, 2013, 07:23:41 pm »
you can set a manual soldermask pullback. Go into the polygon properties and set the soldermask expension to -100mil or so to start with.
Verilog tips
BGA soldering intro
« Reply #3 on: July 20, 2013, 10:06:34 pm »
The option is available for Polygon Region but not for Polygon Pour ...
Offline marshallh
    • retroactive
« Reply #4 on: July 20, 2013, 10:43:25 pm »
Probably easiest to manually draw a new Polygon region over the existing polygon, on the soldermask layer. Use the 3d view to make sure it works right.
Verilog tips
BGA soldering intro
« Reply #5 on: July 20, 2013, 10:51:41 pm »
Ok ... thanks
« Reply #6 on: July 21, 2013, 04:25:38 am »
Ah now i understand whatyou mean. I thought 'thin' a polygon as in make it smaller. So i gave you how to edit it. You want to open the soldermask on it.
here is a trick. Select polygon. Edit - copy - click on a pad of a component . Any component but remeber where you clicked. Now, in the inspector : change the layer of the polygon to top solder ask. If it asks to repour, say no.
Now do edit-paste and click again on the pad of the component you picked when you did edit copy.
Basically what i am doing is storing a copy of the polygon i. The clipboard , using a component pad as origin. I use a component pad as it is a point and altium will 'snap' to the exact centerof the pad.
Then i alter the layer of the existing polygon, telling altium not to redraw it.
After that i paste my copy from the clipboard back in , using that component pad as the placement origin.
This trick works with anything you want to move layers.
