Author Topic: Is it possible to change schematic template?  (Read 7858 times)
Offline RDXxTopic starter
« on: May 18, 2014, 02:56:36 pm »
I am using altium 9.4, and I am having problem with changing the schematic template.
If I double click on the header, the document option "template File name" is grayed out and not changeable.
The only template that I can change is in preference/Schematic/general/"Defaults  template"
But this option only change the template for the new schematics that I add to the project.
Is there a way to replace the current template to another one for a already made schematic?
Offline free_electron
    • SiliconValleyGarage
Re: Is it possible to change schematic template?
« Reply #1 on: May 18, 2014, 03:12:48 pm »
Detach the current template first.
Then add a new one.
I'm not exactly sure how it worked in those older versions.. We're at 14 now...
« Reply #2 on: May 18, 2014, 03:26:03 pm »
Thanks!!!!   :-+ You saved me from at least 2h of extra work.
I found it under Design/Template/...
