Author Topic: Problem routing vias  (Read 2700 times)
Offline m-joyTopic starter
« on: December 28, 2013, 02:25:44 pm »
Hello every one,
i am  having problems with via routing. So while routing a line, i press button "2", and the via appears, but the via does not stay at the last routed line, but on the first routed line. Hard to explain, a screenshot is attached.
As you can see, the via does not stick to my cursor.
Greetings
Offline asadi.siyavash
Re: Problem routing vias
« Reply #1 on: January 02, 2014, 09:35:07 am »
Hi joy,
yes when you using button "2" the layer doesn't change for having via with layer change press "+" or "-".
good luck.
« Reply #2 on: January 02, 2014, 09:54:29 am »
Huhu,
Thank you. That  is true, the layer does nog change with button 2.but the Problem is somethingelse. I start routing at a pad and want to find my way to a place away . The line i am rrouting is changing the direction, now i press button 2 and the via gets places at the first straight line visible, and not the line after it made a corner... And that often disturbs me. Can i change this option?
Greets
« Reply #3 on: January 02, 2014, 10:28:14 am »
Huhu,
jeah when i press left mouse the first line is routed, then the via sticks to the second line which is fine for me, but i thought its possible without routing the first line....
Greetings
« Reply #4 on: January 02, 2014, 10:38:57 am »
I don't know I understood what you said or not, but I think with press "1" when you route a track and then add via. your problem will be solve.
before pressing "1"
after pressing "1"
« Reply #5 on: January 02, 2014, 10:59:01 am »
Woahh jeah that was it ! Thanks a lot. Sometimes things can be so easy =)
Greetings
