Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
sheet entry not linked to child sheet / multi sheet design
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: sheet entry not linked to child sheet / multi sheet design (Read 2667 times)
vixo
Regular Contributor
on:
September 27, 2019, 11:14:15 am »
I tried to make a multi sheet design and found myself getting some strange errors. I made a sheet and repeated it 6 times and repeated the inputs, but I keep getting a "sheet entry not linked to child sheet" error when compiling and the changes wont update to the PCB. The ports are the same name, the child sheet is included in the project and the inputs / outputs are the same. I looked in the 'synchronize sheet entries and ports' menu but everything is matched
picture attached
can anyone help shed light on this problem?
Logged
thm_w
Super Contributor
Country:
Non-expert
Re: sheet entry not linked to child sheet / multi sheet design
Reply #1 on:
September 27, 2019, 08:37:30 pm »
You have project options for Net Identifier Scope set to automatic or hierarchical right?
https://www.altium.com/documentation/18.0/display/ADES/((Creating+Connectivity))_AD
Logged
Profile -> Modify profile -> Look and Layout -> Don't show users' signatures
ajb
Super Contributor
Country:
Reply #2 on:
September 27, 2019, 08:57:09 pm »
Try renaming the sheet entry from "Repeat(in1)" to "Repeat(volt)"? That's how the Altium documents show it, the repeat syntax is funky and I think only works if you make the names match between the sheet entry and the wire connecting to it.
Also it looks like you're missing a comma in the Repeat() on the sheet name.
https://www.altium.com/documentation/18.0/display/ADES/((Multi-Sheet+and+Multi-Channel+Design))_AD
Logged
T3sl4co1l
vixo
Regular Contributor
Reply #3 on:
September 29, 2019, 02:00:21 pm »
thanks! I had a few problems, one of which was the incorrect repeat syntax, but I also found elsewhere that altium doesn't like spaces in the port names
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
