Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Altium 1:1 print output
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Altium 1:1 print output (Read 16389 times)
richcj10
Supporter
Country:
on:
November 18, 2013, 03:48:17 pm »
I think I have it scaled correctly using the page setup. But when I print, I get a blank page. The printer is B/W and I have tried it in mono and gray. Any Ideas?
Logged
owiecc
Frequent Contributor
Country:
Re: Altium 1:1 print output
Reply #1 on:
November 18, 2013, 07:27:11 pm »
Can you see your layout on the preview? Try printing from Altium to PDF. This should tell you if it is Altium or printer issue.
Logged
richcj10
Supporter
Country:
Reply #2 on:
November 19, 2013, 05:58:31 am »
Yes, I can see it on the preview.
How do I get it out of altium in pdf at 1:1 ?
My printer works fine. I can print from any other program.
Logged
gocemk
Regular Contributor
Country:
Reply #3 on:
November 19, 2013, 12:08:18 pm »
You must set Adobe PDF (or CutePDF) as your default printer, otherwise it won't work. (at least in my case). Then, print it as pdf, and save it. Then you can review your design in pdf and print it on a printer.
Hope this helps.
Logged
Psi
Super Contributor
Country:
Reply #4 on:
November 21, 2013, 08:18:15 am »
Quote from: richcj10 on November 19, 2013, 05:58:31 am
(Altium designer summer 09)
Right click on the fabrication previews your printing and click "page setup"
Change the scaling to "Scaled print" and set it to 1
That will print 1:1 (i've used it many times to do toner transfer)
You can print to a PDF printer to get a 1:1 pdf then print later if you want. i've done that too
If you find the output isn't 1:1 when printing the PDF then it's an issue with your PDF software.
Last Edit: November 21, 2013, 08:30:05 am by Psi
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
