Author Topic: Schematic net list, off page connectors  (Read 1501 times)
Offline gogomanTopic starter
« on: October 12, 2017, 12:44:18 pm »
Hi  several problems and need some help.
in the schematic can nets be listed for each page and Is  there a quick method to find where the net are used?
The tool reports unconnected nets which are off page  even if the net name are identical.
thanks
Offline tszaboo
Re: Schematic net list, off page connectors
« Reply #1 on: October 12, 2017, 12:56:01 pm »
Altium is using hierarchical design by default, which means you need to explicitly tell it, that you want two off sheet nets are connected. Its with the port, not with the netlabel. And multiple nets can have the same name, but not connected. It allows greater flexibility.
Please read this to understand.
http://www.altium.com/documentation/17.1/display/ADES/((Creating+Connectivity))_AD
It is a steep learning curve.
Also, the navigator panel's "interactive navigation" button helps.
The following users thanked this post: adamcord
« Reply #2 on: October 13, 2017, 04:58:26 am »
good read.
anther question, when printing the schematic several unrelated sheets are  combined together on a single page.
Is  a what you see is what you get option available when using smart PDF
thanks
