So I'm trying to learn altium again. Tried some time ago with v18 and it seemed to work ok from what I can remember. However now with v20 is super slow...
Just selecting a pin in when creating a footprint takes 1 second for it to load the properties panel, clicking outside the pin again on the work area takes another second, etc....
For example, trying to draw this resistor symbol takes approx 1 second for every time I have to click and change the direction of the diagonal line...
Is there nothing I can do about this?
Specs:
Surface sp4
i5-6300 2.4GHz
8GB Ram
Integrated graphics, intel HD 520
256GB sdd
Do I really need to buy a dedicated workstation with an i7, 16gb ram and a dedicated graphics card for this?
On a Surface ? you're joking right ?
No, I'm obviously not joking. Also when loading one of the included example projects (even the bigger ones) pcb routing, 3d viewer and schematic capture seems to work just fine with with barely any lag. Creating schematic symbols for specific is where it's it's taking it's time loading for 1 second everytime I click on a pin, line or component. I dont know if it has anything to do with the supplier search because it feels like it is constantly trying to fetch all the metadata from digikey as soon as I click any of the component pins/lines.
Blueskull mentioned the schematic will constantly re-compile, I'm not sure if that is something you can disable in the options (like online DRC). Also dedicated GPU required.
I would just go back to v18.
Yea that sounds lke something that would cause every click to take 1 second. I'll check if I can disable something else. But yes, will probably revert to v18 which worked really smooth on my surface.
List panel open?
It didn't used to be broken but in 18 or so they really screwed it up. SCH List is just about useless. PCB List is still fine (keep it set to "edit/view selected" though).
In general, 20 is a lot slower than previous versions. It's dumb, go figure.
Yea I had the list panel open, will try to hide it and see if that helps! Really wanted to get v20 to work since the new router looks super nice.
