Author Topic: Using Multiboard with non pcb components  (Read 1722 times)
Offline ahbushnellTopic starter
« on: August 23, 2020, 04:51:21 pm »
I started working with the multiboard tool in Altium.  It looks handy.  I would like to be able to connect external components that are not PCB's.  Is there a way to do that?  For instance a commercial power supply.
Thanks
Andy
Re: Using Multiboard with non pcb components
« Reply #1 on: August 27, 2020, 03:32:24 am »
I'll answer my own question.  It looks like you can only connect boards together.  To bad.  Maybe that will be in release 21.  :)   :-//
Offline Berni
  • Country: si
« Reply #2 on: August 27, 2020, 05:17:26 am »
If you want to use the multiboard workflow to put a power supply into your design then just make a tiny board that is hidden inside a 3D step model of the power supply, then import that.
The following users thanked this post: ahbushnell
Offline vikebo
  • Country: no
« Reply #3 on: October 02, 2020, 07:58:11 am »
Not sure if it has been added later, but I'm using 20.1.14 and have "Insert STEP Part..." available when assembling the boards in .MbaDoc.
