Author Topic: Choosing footprint from library.  (Read 5108 times)
Offline flodinsTopic starter
    • flodins.info
« on: June 11, 2011, 01:45:58 am »
Hi
I have a problem with adding items from my own library for which I defined many footprints. On the schematic always lands with a default value, unless I select the Place but it is too much clicking. If you add the built-in library, this problem does not occur I can grab a footprint that interests me and this will be set on the schematic.
Do you know any solution? Something had to switch in my library?
I think that the movie clearly shows all
http://flodins.info/footp.mp4
Offline thmjpr
Re: Choosing footprint from library.
« Reply #1 on: June 11, 2011, 05:08:54 am »
Weird, don't see that problem in AD9.3. Is this AD10?
All I can think is create a new library project, copy a part over, compile/install and see if it persists.
    • flodins.info
« Reply #2 on: June 11, 2011, 10:12:06 am »
this is AD9
Offline armandas
  • Country: jp
    • My projects
« Reply #3 on: June 11, 2011, 12:01:13 pm »
Did you specify the correct footprint in your schematic library?
    • flodins.info
« Reply #4 on: June 11, 2011, 12:08:41 pm »
yes, you can see that when click place it works, only grabing from my libraries does not work grabing from build in librares is ok
Offline FreeThinker
  • Truth through Thought
« Reply #5 on: June 11, 2011, 05:05:18 pm »
I've never used altium but did you save the footprint with a value attached (ie when you designed it) if so then that would most likely be the problem. If not and altium is assigning a random value (when saved ) then it is indeed strange.
Edit < Just re watched  the video and you have got the value item ticked in the parameter list. Does this not display the value?>
« Last Edit: June 11, 2011, 05:11:17 pm by FreeThinker »
Machines were mice and Men were lions once upon a time, but now that it's the opposite it's twice upon a time.
MOONDOG
