Author Topic: Altium: Blind/Burried vias in footprints?  (Read 2930 times)
Offline TheUnnamedNewbieTopic starter
  • mmwave RFIC/antenna designer
« on: September 25, 2020, 08:32:18 am »
I'm making a HDI project with lots (well actually only) blind and buried vias. In some of the footprints I need to make (RF structures) I need to have blind/buried vias. I cannot for the life of my find how to do this. In the PCB library stackup editor (not the PCB stackup editor itself), it seems like you cannot add any non-through vias.
Is this something Altium simply cannot do, and I have to use another tool, or am i just not seeing the button to do it?
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline SerieZ
  • Zap!
Re: Altium: Blind/Burried vias in footprints?
« Reply #1 on: September 25, 2020, 01:57:11 pm »
As far as I am aware you cannot define Via Types in your Footprint in Altium.
However if I had the same problem you are facing I would give those affected vias a "special" size, impossible for manufacturers (i.e 0.201) and later filter those out (Find Similar) in the Layout and change them all in few clicks to the desired via type previously defined in the Layer Stackup in the Layout itself.
To Clarify:
Select all those Components in the Layout and unlock primitives -> then filter by Find Similar function
« Last Edit: September 25, 2020, 01:59:34 pm by SerieZ »
As easy as paint by number.
« Reply #2 on: September 26, 2020, 09:01:02 am »
That is a very nifty work-around. I have currently decided to give Keysight ADS a try for this specific board, since it is just a series of RF structures, but might use this in a next iteration when we add active circuitry to the PCB.
Thanks!
Offline dstraight
« Reply #3 on: October 06, 2020, 05:26:43 pm »
My workaround: I created my footprint using blind/burried vias in the PCB project document - then I copied the structure into the PCB footprint library.
I'm not sure if this is the best approach - but this seems to work.
The following users thanked this post: free_electron
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: October 25, 2020, 04:45:04 pm »
The library can store anything that can be created on the pcb. the Library EDITOR is limited in functionality though. for this kind of work : make the structure using the PCB editor first , then copy past into library.
i have been pushing altium to drop the pcb library editor altogether and use the pcb editor instead. instead of saving as a pcbdoc you save as pcblib or pcbpart.
Offline Gibson486
« Reply #5 on: November 03, 2020, 02:40:25 pm »
I tried doing this the way dstraight did. Did not work. The issue is that you need to define your vias by layers ahead of time. So, if you have a part that was on a 4 layer pcb, then the buried via would get messed up on the 6 layer pcb. The work around is that you can manually make it right by adjusting it after you import the part in, but that kind of beats the whole point.
