Author Topic: Apply different rules in particular area  (Read 2654 times)
Offline hamdi.tnTopic starter
  • Country: tn
« on: August 20, 2014, 11:13:43 am »
hi everyone,
So anyone have an idea how to define clearance and width rules for a particular area in PCB   |O
I tried room and  create class and so without success i don't know what am doing wrong   :scared:
Offline owiecc
    • Google scholar profile
Re: Apply different rules in particular area
« Reply #1 on: August 20, 2014, 01:00:04 pm »
Are your rules in correct order? Try changing priorities.
After every change in the rules re-run the DRC.
Offline avaldezc92
  • Country: mx
« Reply #2 on: August 20, 2014, 05:26:55 pm »
In the Design Rules, press Query Builder and in the condition select "Belongs to Component Class" then select the room.
  • Country: tn
« Reply #3 on: August 20, 2014, 11:43:10 pm »
@owiecc - yes i did set priority and Online DRC still show track with special clearance as faulty
@avaldezc92 -That's exactly what i did  :-//
anyway i did this routing manually many thanks  ;)
Offline owiecc
« Reply #4 on: August 21, 2014, 05:54:33 am »
Online DRC has failed few times for me this is why I suggested to re-run the thing manually. After I do the DRC manually the online one works ok. It just looks like some of the errors are not updated wen you change the rules. Maybe it depends on the Altium version.
Offline avaldezc92
  • Country: mx
« Reply #5 on: August 22, 2014, 03:26:07 pm »
Try what @owiecc said. Run DRC manually and see what happends.
