Author Topic: altium14  (Read 4649 times)
Offline ant17Topic starter
altium14
« on: December 18, 2013, 11:31:55 pm »
hi i have just stared using this and found that when i try to make a simple circuit i  get the error no signal pin has no driver could someone help
Offline free_electron
    • SiliconValleyGarage
Re: altium14
« Reply #1 on: December 19, 2013, 12:25:14 am »
you have a floating input somewhere.
doubleclick the error ant it will tell you where
Offline JDubU
Re: altium14
« Reply #2 on: December 19, 2013, 06:25:59 am »
If you want the pin to float without a driving source on it, place the "NO ERC" (red X) symbol on it instead of a wire end.  It will prevent the warning.
Offline hyprfrcv
Re: altium14
« Reply #3 on: April 23, 2018, 04:43:27 pm »
This error appears in Altium Designer when working with free schematics. If you add the schematics into a project, the error dissapears.
It is possible to discard this error working with free schematics?.
