Author Topic: Net Highligh too dark  (Read 1630 times)
Offline rascupanamuhaTopic starter
  • Country: hr
« on: February 18, 2016, 01:56:58 pm »
Hi. This is my first post here and i need help :)
The problem is that my net highlighthing (ctrl+left mouse click on net) become too dark so i cant see other nets.
How can i revert id back to normal highlithing?
Offline defter
Re: Net Highligh too dark
« Reply #1 on: February 18, 2016, 03:19:22 pm »
SHIFT+C clears the highlighting. You can set highlighting factor in the down right corner under mask level.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: February 18, 2016, 04:51:27 pm »
The [ and ] keys change the mask level as a shortcut, too. :)
Seven Transistor Labs, LLC
