Author Topic: How to draw drill hole in PCB Gerber File?  (Read 3953 times)
Offline MechatrommerTopic starter
  • Country: my
  • reassessing directives...
« on: October 03, 2016, 12:14:06 pm »
in Altium, PCB Gerber doesnt have drill hole information... i need this so where the drill hole, the copper on the pcb will be etched out to make drilling bit easy. i remember i can do this in DipTrace. like the guy below, he has copper etched out already at drill hole location... please help...
Offline Jeff_Birt
Re: How to draw drill hole in PCB Gerber File?
« Reply #1 on: October 03, 2016, 12:23:26 pm »
The Gerber files do not contain drill information. That is what the Excellon drill file is for. Before I made my boards via a Taig CNC mill I used to print out a 1::1 print on a transparency and expose pre-sensitized boards with a UV lamp. Since these were drilled by hand on a small dill press, by me wearing a jewelers magnifying headset, I would reduce the inner diameter of every pad to a pin point. That way a tiny circle was all that was etched off the board and it made a perfect small spot to locate the drill.
To do this you have to make a copy of your file and change all pads the small ID. I don't recall how I did this in Eagle, I may have run a ULP to do it automatically.
Online jpanhalt
« Reply #2 on: October 03, 2016, 12:46:43 pm »
Yes, Eagle has a ULP for making small etched spots to help center the drill : drill-aid.ulp
As for the original question, I can understand the need to have a clear zone around a hole, but for hand drilling, I would still keep a pad there with an etched center for locating and centering my drill.
Sorry,  can't answer how to do it in Altium.  In Eagle, use a round polygon as if making a copper pour.  You can also use a keepout layer and a regular geometric shape, but that would make it harder to put a small pad in the center.
John
« Last Edit: October 03, 2016, 12:53:32 pm by jpanhalt »
  • Country: my
« Reply #3 on: October 03, 2016, 05:17:53 pm »
meh, so much so for multi thousands business software. in the end if you want to get satisfied, you have to make your own...
