Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Same net track clearance during an interactive routing
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Same net track clearance during an interactive routing (Read 1427 times)
Vogelek23
Newbie
Country:
on:
October 30, 2017, 12:52:05 am »
Hello dear colleagues.
I have a serious problem with design rules in Altium Designer 10. I can't set up a fixed clearance between two or more tracks which belong to the same net. I want to draw an octagonal RFID PCB antennae (70x50mm outer and 30x10mm inner diameter). I have set a track width (0.35mm - critical) and a fixed clearance (0.20mm - critical) but when I'm starting an interactive routing, Altium does NOT keep that fixed clearance between the turns (I can easily make a short across all the drawn turns during coil drawing). I have switched a clearance rule to "Same Net Only" (under Design -> Rules) but it still did not avoid shorts during routing, so I have changed this option to "Any Net" - it now does not allow me to make a shorts between turns and seems to keep the clearance, but it also does not allow me to draw the rest of the turns!
Does anybody know how to keep a fixed clearance between tracks with the same net during an interactive routing?
Logged
Ice-Tea
Super Contributor
Country:
Re: Same net track clearance during an interactive routing
Reply #1 on:
October 30, 2017, 08:53:58 am »
Net tie perhaps?
https://www.smtnet.com/library/files/upload/NetTies-and-How-to-Use-Them.pdf
Logged
eBay shop with all the gear you need!
voltsandjolts
Supporter
Country:
Reply #2 on:
October 30, 2017, 07:01:44 pm »
Yeh, clearance rules operate between different nets, your working on the same net.
Maybe easier just to setup an appropriate grid or place snap points (point guides) before routing.
Logged
Someone
Super Contributor
Country:
Reply #3 on:
October 30, 2017, 11:55:24 pm »
Its best done with scripting, some primer material here:
http://blog.mbedded.ninja/electronics/general/altium/altium-scripting-and-using-the-api/pcb-related-api
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
