Author Topic: Online DRC after update PCB documents takes forever!  (Read 10536 times)
Offline slow_riderTopic starter
« on: December 14, 2014, 02:03:11 pm »
I just finished a schematic with about 16 op-amps and about 60 other components. I go to update PCB document.... and after clicking execute changes the bar is taking forever to complete. After 10 minutes it is about 30% done. I went to DRC and removed all the checks from online checks but does not seem to made any effect. Is this normal? I am running a pretty new machine that handles SolidWorks without too much trouble and in general I don't think it's a hardware thing. I'll appreciate suggestions!
Online T3sl4co1l
    • Seven Transistor Labs
Re: Online DRC after update PCB documents takes forever!
« Reply #1 on: December 14, 2014, 02:38:15 pm »
Yeh, how many lines are in the ECO?  Thousands?
Typical seems to be maybe five lines per second, so an update to a brand new PCB file can take minutes.
It should not be taking ten minutes or more.
As far as I know, nothing in the PCB view (DRC, rendering or other) is active during ECO.
Are there any issues with file access, perhaps from working off a network drive?
Seven Transistor Labs, LLC
« Reply #2 on: December 14, 2014, 08:09:43 pm »
All the files are located on my hard drive... I also came back and saw that it placed most of the components one on top of the others so now everything is grouped in an impossible way and when I tried to move this bulk (since Altium placed it way outside far from the board area) it started with the DRC again... Oh man...
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: December 16, 2014, 04:42:12 pm »
change the drc choices in the drc manager
T-D , click 'rules to check in the left pane.
you get a grid. in the column 'online'  disable all but short circuit , clearance , net antennae
in your project settings : C - O  under class generation : turn off rooms if you don;t use those.
in the design rules  D-R  disable all but clearnace,planeconnect,polygonconnect,unroutednet and width.
your machine should now blast through the online checker.  the other stuff you really dont need during active layout. ( unless oyu are doing controlled impedance , bga fanout etc )
those can be run in the batch processor as part of the release
The following users thanked this post: photovore, dansku
Offline shakaibsafvi@gmail.com
« Reply #4 on: March 10, 2016, 09:03:12 am »
Hi
If you have used Teardrops, try removing them and route the whole board. Then add Teardrops, Polygon Pours, DRC etc....
