Author Topic: Highlight intensity  (Read 2832 times)
Offline blueskullTopic starter
  • Country: cn
  • BA7LKP
Highlight intensity
« on: July 20, 2016, 06:17:32 am »
I have "over" highlighted nets in AD. When I try to place a track (PT), or try to drag any thing with a net, the entire board goes dark.
I remembered it did not do this before. It only darkens the rest nets a little, not this much.
How can I set the intensity back to normal? I tried to restart the software, and intensity option in preference, with no luck.
Thanks.
Offline radar_macgyver
Re: Highlight intensity
« Reply #1 on: July 20, 2016, 06:36:24 am »
Its the box bracket keys that increase and decrease highlights. You can also use the menus that appear when you click "Mask level" on the bottom right.
This happens a lot to me, since I use the 'P' shortcut which is right next to '['.
The following users thanked this post: blueskull
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: July 20, 2016, 05:09:41 pm »
Here's one that'll uncook your mind, for multilayer designs:
Shift+S
:P
Seven Transistor Labs, LLC
Offline D3f1ant
  • Doing as little as possible, but no less.
« Reply #3 on: July 20, 2016, 07:01:53 pm »
Speaking of highlights, does anybody know if it's possible change 'crossprobe' from mask to dim?
